  • Kim Grandgagnage 63 posts 87 karma points
    Jan 04, 2012 @ 12:50
    Kim Grandgagnage
    Update quantity problem
    I am using the [DocCart]ViewCart.xslt to display the items in my shopping cart. How can I update the cart when a user changes the quantity for a specific product? When I click the update button, the page only refreshes but the new quantity is not saved in the cart. Another thing: how can I update the quantity of the product in the cart, without the Update button? I would like to let it update my cart with an onChange event of my input field (quantity).
    I use the following code:
    <xsl:variable name="formAction" select="umbraco.library:NiceUrl($currentPage/@id)"/>
     <xsl:variable name="items" select="DocCart:CartAsXml()/Items/Item"/>
    <form action="{$formAction}" method="post">
     <xsl:for-each select="$items">
     <td class="gAantal">
                      <input id="num-pallets-input{position()}" class="num-pallets-input" type="number" name="Quantity">
                        <xsl:attribute name="value">
                          <xsl:value-of select="Quantity"/>
                        </xsl:attribute>
                      </input>
                      <label visible="false" for="num-pallets-input{position()}" class="errorcross" style="display: none;">
                        <img src="/images/unchecked.gif" alt="unchecked" /></label>
                      <input type="hidden" name="ItemId" value="{@NodeId}"/>
                      <input type="submit" name="submit" value="Update"/>
                  </td>
    </xsl:for-each>
     </form>
    Thanks in advance.
    grts,
    Kim
