    Apr 02, 2011 @ 12:03
    Anthony Candaele
    how to add the dropdownlist to a masterpage
    Hi Yannick,
    I downloaded version 1.0 of the Multi-language tools package, and I'm trying add a dropdownlist with flags to my masterpage, but I don't know how to do this. I added this razor code to my masterpage:
    <umbraco:Macro Language="cshtml" runat="server">
    @RenderPage("~/macroscripts/MultiLanguage/LanguageSwitcher/List.cshtml")
    umbraco:Macro>
    but then if the page is rendered I get the error message:
    "Error loading Razor Script The file "~/macroscripts/MultiLanguage/LanguageSwitcher/List.cshtml" could not be rendered, because it does not exist or is not a valid page"
    Am I missing something, or should I do more besides putting the LanguageSwitcher.cshtml in my MacroScripts folder?
    Thanks for your advice,
    Anthony
  • Yannick Smits 321 posts 718 karma points
    Apr 02, 2011 @ 12:13
    Yannick Smits
    There is no option to render a dropdownlist with flags (yet). Either a list of flags or a a dropdownlist.
    There should be no LanguageSwitcher.csthml in the package so it is definitely not enough to place this file in the macroscripts folder. Have you installed the package?
    Apr 02, 2011 @ 12:23
    Anthony Candaele
    I if click the download link on the package page, the only thing that is downloaded is the languageswitcher.cshtml file. Or should I download the package from another page?
    Apr 02, 2011 @ 12:28
    Yannick Smits
    ah I see! have to set the current release in the project settings to the new package file. Didn't know that. Please download again and make sure it's a zip file called Goyaweb_Multi-Language_tools_1.0.zip
    Apr 02, 2011 @ 16:08
    Anthony Candaele
    Hi Yannick,
    I downloaded the Goyaweb Multi-Language tools and installed the package. The dropdownlist works fine on my page. Is it possible to add the MLLanguageSwitcher macro to a template, or can it only be added to a page?
    thanks for your advice,
    Anthony
    Apr 03, 2011 @ 00:31
    Yannick Smits
    you can do both.
    Apr 03, 2011 @ 08:18
    Anthony Candaele
    Hi Yannick,
    It works perfectly! This package is a great contribution to Umbraco.
    Thanks a lot,
    Anthony
  • Liliana 5 posts 25 karma points
    Apr 08, 2011 @ 12:22
    Liliana
    Hi, I know little Umbraco and I want to know  if there is no video for the installation of version1.0 of the Multi-language tools package. For my level would be much easier to understand. Thanks.
    Liliana
    Apr 08, 2011 @ 12:26
    Yannick Smits
    Hi Liliana, there is not much to it really. It's like any other package. Install it, insert a macro in your template, set the macro variable to either List, DropDown or Flags and you're set!
    For a video on what a macro is you could check:
    http://umbraco.com/help-and-support/video-tutorials/introduction-to-umbraco/sitebuilder-introduction/what-are-macros
    Apr 08, 2011 @ 13:31
    Liliana
    Thanks, I try it and I tell you.
    Apr 11, 2011 @ 14:40
    Liliana
    It's instaled, but I obtains a  empty dropdown. What do I do?
    Apr 11, 2011 @ 16:54
    Yannick Smits
    How many languages did you install into your website? Can you see them in the Languages node in the Settings area? Have you applied the languages to your root nodes?
    Apr 14, 2011 @ 11:07
    Liliana
    I will instal 3 languages, but now, I have another problem. In fact, Umbraco does not recognize my admin password. I dont know why.  I must start over...
    Apr 14, 2011 @ 11:28
    Liliana
    I found where was the problem, I can continue with my site. See you soon and thanks!
    Apr 15, 2011 @ 10:51
    Liliana
    Hi... it' me yet,
    now I obtain a dropdown wiht 1 languages.  In the Languages node in the Settings area I have 3 languages.
    In the backend administration, how do I obtain the 3 windows for the 3 languages?
    And ..." applied the languages to your root nodes" ...I dont see... can you explain this?
    Apr 16, 2011 @ 19:25
    Liliana
    Hi, Yannick
    I'm really sorry!!!
    The package was installed successfully...is realy  simple!! Thanks a lot!
    Just the link is not functional... do you want help me...again?
    Apr 16, 2011 @ 20:22
    Liliana
    no problem.  I found.  I am very happy. Thanks and  goodbye
