First, great package! Now I have a requirement that when the user selects a language that the choise is remembered. Is there a way to do this with this package?
unfortunately, I don't find the right place in the Functions.cshtml to insert a language remembering cookie or session variable. Could someone help, where should I place the code?
Remembering language
Thijs
Sorry, not possible with this package. But the (razor) source code is included so you can easily add it yourself.
Thank You!
Csaba
