  • Jorge 7 posts 27 karma points
    Aug 21, 2012 @ 15:46
    Jorge
    Possible to restyle & rename languages?
    it works like a charm. Thanks! I was wondering if it is possible to modify the language names in the list version of language switcher. e.g EN in place of English I would like to use.
    My second question is that the selected language is styled strong. Is there a possibility to get rid of it?
    Thanks in advance
    Aug 21, 2012 @ 15:51
    Jorge
    I can't edit my question. It gives some error that is why I am reposting. Ignore my second question please, I already found a work around for it, however my first question is still open.
  • Yannick Smits 321 posts 718 karma points
    Aug 21, 2012 @ 16:34
    Yannick Smits
    Yes you can.
    Just change the List.cshtml file from @data.NativeName to @data.CountryCode or @data.LanguageCode
    Aug 21, 2012 @ 17:28
    Jorge
    Perfect! Thanks a lot.
