After upgrade to 6.1.0, I found the library.GetCurrentDomains() function will return null when I set a language to the regional home page and no domain name associate to it. Do you have any idea to fix the GetLanguageIdFromNodeId() function in Functions.cshtml?
not compatible to 6.1.0
Hi Yannick,
I never really tested the scenario where no domain name is associated but let me know if you make a fix.
