CopyDocumentToRelatedOnPublish.cs does not seem to have any effect (umb 7.1.8)
Hi all,
I'm been trying to make a multilanguage 1:1 site with the following structure
mysite.com/en
mysite.com/es
mysite.com/fr
etc...
We have set culture and hostnames for each of those root nodes (en, es, fr).
I have just seen that, according your documentation:
CopyDocumentToRelatedOnPublish.cs will automatically create a copy of the new Document to all other language nodes and relates them.
It doesn't seem to work at all in our Umbraco 7.1.8 installation. Does anyone else see this behaviour? It simply does nothing, no errors, but no new docs either are created under the rest of the languages whenever we create & publish a new doc under /en/ for instance.
You should first create the English site and then use the Copy function to copy the english node. While you do that you should tick the "relate noded" option.
Hi all,
Any idea? Thanks in advance.
