hi,
I have a problem with Umbraco I need to create another page and when I create a document type with a template it does not appear in the nav and when I create a document type without a template and link it with a template I created it does not work. It just works and appears in the nav when I copy another document type. but when I add a template to it not work as a model and I can't call it from another page. example I created a blog post page and blog articles page I copied them from the project page and the project list page. when I work with it the @model does not work and I can't use @inherits Umbraco.Web.Mvc.UmbracoViewPage<Blog>. It gives me the error " redirected you too many times. "
and it works when I remove <Blog> from the code. and can't call it from the blog list page. and the same with the blog list page.
this is the code
problem with Model and creating new document type (redirected you too many times. )
hi, I have a problem with Umbraco I need to create another page and when I create a document type with a template it does not appear in the nav and when I create a document type without a template and link it with a template I created it does not work. It just works and appears in the nav when I copy another document type. but when I add a template to it not work as a model and I can't call it from another page. example I created a blog post page and blog articles page I copied them from the project page and the project list page. when I work with it the
@model
does not work and I can't use@inherits Umbraco.Web.Mvc.UmbracoViewPage<Blog>
. It gives me the error " redirected you too many times. " and it works when I remove<Blog>
from the code. and can't call it from the blog list page. and the same with the blog list page. this is the codeand the code that copied from
I hope some help
I hope I have clarified the problem.
thanks
