  • Gerard Konings 6 posts 55 karma points
    May 20, 2016 @ 08:39
    Gerard Konings
    Running grunt dev
    I'm trying to get the source from github running, but I'm having trouble with the Grunt dev command. It throws an error and runs with an error in the angular file.
    I followed the guide on the github page, but I'm thinking I might be doing something wrong. Anyone any Ideas?
    It works fine when I run just Grunt btw. But it is a pain in the * to develop that way
    Jun 20, 2016 @ 16:56
    Gerard Konings
    Givin' a subtle bump of this topic on it's first month anniversary. Because I only have a macbook at home and I'd like to just run the client with mock data it would really help me.
  • Timo Perplex 13 posts 145 karma points c-trib
    Sep 08, 2016 @ 10:11
    Timo Perplex
    Hi Gerard,
    I'm having the exact same issue. I've added the error below in text because I could not find anything on google or Our with the error message:
    angular.min.js:63 Error: Unknown provider: resetPasswordCodeInfoProvider <- resetPasswordCodeInfo
        at Error (native)
        at http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:29:439
        at Object.c [as get] (http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:27:142)
        at http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:30:21
        at c (http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:27:142)
        at d (http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:27:276)
        at Object.instantiate (http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:28:434)
        at http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:53:326
        at http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:44:274
        at n (http://localhost:9990/belle/lib/angular/1.1.5/angular.min.js:7:74)(anonymous function) @ angular.min.js:63
    http://localhost:9990/favicon.ico Failed to load resource: the server responded with a status of 500 (Internal Server Error)
    No solution yet though :/.
