I wanted to start contributing to Umbraco, so I decided to get the source code and try building it, in order to at some point create my first pull request.
I have tried following the quick start guide, so I have forked the official repostiory, and I have the dev-7 branch checked out.
I'm running Win 10 Enterprise inside a VM, and have VS2017 installed When I run the Build.bat file the build process fails very quickly with the following error, and I have no clue how to proceed. Any help to point me in the right direction would be greatly appreciated:
I'm getting this error, when running the Build.bat:
Building Umbraco 7.6.4
Removing the belle build folder and bower_components folder to make sure everything is clean as a whistle
The system cannot find the file specified.
Removing existing built files to make sure everything is clean as a whistle
Making sure Git is in the path so that the build can succeed
git version 2.13.1.windows.2
The system cannot find the path specified.
Making sure we have a web.config
Visual Studio is installed in: C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional
Reporting NuGet version
NuGet Version: 4.1.0.2450
Restoring NuGet packages
Into C:\Dev\Umbraco-CMS\build\..\src\packages
WARNING: Project file C:\Dev\Umbraco-CMS\src\http://localhost:3961 cannot be found.
Performing MSBuild and producing Umbraco binaries zip files
This takes a few minutes and logging is set to report warnings
and errors only so it might seems like nothing is happening for a while.
You can check the msbuild.log file for progress.
Microsoft (R) Build Engine version 14.0.23107.0
Copyright (C) Microsoft Corporation. All rights reserved.
C:\Dev\Umbraco-CMS\src\umbraco.presentation.targets(68,38): error MSB4022: The result "" of evaluating the value "$(Web
PublishingTasks)" of the "AssemblyFile" attribute in element <UsingTask> is not valid. [C:\Dev\Umbraco-CMS\src\Umbraco.
Web.UI\Umbraco.Web.UI.csproj]
Errors were detected!
Can't comment on the specific error with the batch file, but in my experience you can build the solution using Visual Studio and the front-end by running the grunt tasks specified in the readme of the Umbraco.Web.UI.Client folder.
So don't believe it's actually necessary to use the batch file.
Help building Umbraco Source
Hi there.
Thanks in advance,
Best regards,
David
Umbraco.Web.UI.Clientfolder.So don't believe it's actually necessary to use the batch file.
Hope that helps
Andy
Hi Andy,
Thanks for the suggestion!
I will give it a try :)
Best regards,
David
Hi Andy,
Your solution seems to work.
Thanks for helping out :)
Best regards,
David
