I've not been able to compile the Umbraco source code. I'm ambiguous errors from calling the ExecuteReader. Any ideas?
The call is ambiguous between the following methods or properties: 'SqlHelper
.ExecuteReader(string, params P[])' and 'SqlHelper
.ExecuteReader(string, params IParameter[])'
The function is an override but for some reason VS feels it's ambiguous with the method inherited.
I'm using VS 2015 Enterprise.
Pulled the source via git.
There was an error when running the bak file which seemed to target V11 but I'm using VS 2015 (14)
have you tried pulling source via nuget and seeing if you get the same build error?
just want to make sure its not a file issue
also you haven't specified which build (i guess its the latest)
Ravi
Hi Ravi,
Thanks for replying. I found it to be two separate issues. I was on the wrong branch (master), secondly I needed to apply a work around which was to copy the web applications from the v14.0 folder into a created v11.0.
John
might be worth putting some notes and context if someone else finds this so they can benefit from your experience
best of luck..
ExecuteReader call is ambiguous
Ravi
Hi Ravi,
John
best of luck..
