  • Iaroslav 6 posts 76 karma points
    Dec 26, 2017 @ 09:02
    Iaroslav
    User's AccessFailedCount field is not reset after successful login
    Hi, I've not found such issue in the forum but if it exists, please send me a link and I will close this topic.
    I fount that User AccessFailedCount field is not reset after login. I can see that it stays the same in DB.
    Steps to reproduce: 1. Try to login with a user using wrong password 2 times of 3 in any browser. 2. Login with the same user successfully using right password. 3. Logout. 4. Try to login with the same user using wrong password 2 times. 5. Try to login using right password and you can't do it cause the failed count field wasn't reset previously.
    I found a fix for it. The AccessFailedCount field was updated in DB but not in the BackOfficeIdentityUser reference. So I created custom back office manager and overridden CheckPasswordAsync.
     public override async Task<bool> CheckPasswordAsync(BackOfficeIdentityUser user, string password)
            bool isPasswordValid = await base.CheckPasswordAsync(user, password);
            if (isPasswordValid)
                user.AccessFailedCount = 0;
            return isPasswordValid;
    Now it works properly.
    Could you please answer if it's my bad or it's an issue?
    Thank you very much.
    Dec 27, 2017 @ 11:11
    Alex Skrypnyk
    Hi Iaroslav
    Really good finding, #h5yr!
    Can you make a pull request?
    Oleksandr
    Dec 27, 2017 @ 11:20
    Iaroslav
    Ok, I will try. It's a fix for my project but I'm not sure where I need to put this code in the project. But anyway reviewers will correct me :)
    Dec 27, 2017 @ 11:22
    Alex Skrypnyk
    What version of Umbraco are you using?
    Dec 27, 2017 @ 11:46
    Iaroslav
    Dec 27, 2017 @ 11:50
    Alex Skrypnyk
    Iaroslav, there is no such problem in Umbraco 7.7.7
    Dec 27, 2017 @ 11:51
    Iaroslav
    Ok, great, thank you very much!
    Dec 27, 2017 @ 11:52
    Alex Skrypnyk
    You are welcome, have a great day
