  • dipanwita das 19 posts 100 karma points
    Mar 19, 2019 @ 12:21
    dipanwita das
    ucommerce package installation error index was outside the bounds of the array
    Hello Team, I am trying to install ucommerce package, but error is occured in browser console it says 500 error at http://localhost/umbraco/backoffice/UmbracoApi/PackageInstall/UploadLocalPackage
    and in log file the error is like below
    ERROR umbraco.cms.businesslogic.packager.Installer - Error importing file D:\WebShop\UmbracoUcommerce\UmbracoUcommerce\AppData\0ea55ae1-9f64-45a9-82ab-441ecb6ad366.umb System.IndexOutOfRangeException: Index was outside the bounds of the array. at umbraco.cms.businesslogic.packager.Installer.GetFileName(String path, String fileName) at umbraco.cms.businesslogic.packager.Installer.LoadConfig(String tempDir) at umbraco.cms.businesslogic.packager.Installer.Import(String inputFile, Boolean deleteFile) 2018-08-22 13:31:37,760 [P6896/D2/T50] ERROR Umbraco.Web.WebApi.Filters.FileUploadCleanupFilterAttribute - Could not acquire actionExecutedContext.Response.Content System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Web.WebApi.Filters.FileUploadCleanupFilterAttribute.OnActionExecuted(HttpActionExecutedContext actionExecutedContext) 2018-08-22 13:31:37,767 [P6896/D2/T50] ERROR Umbraco.Web.Editors.PackageInstallController - Unhandled controller exception occurred System.IndexOutOfRangeException: Index was outside the bounds of the array. at umbraco.cms.businesslogic.packager.Installer.GetFileName(String path, String fileName) at umbraco.cms.businesslogic.packager.Installer.LoadConfig(String tempDir) at umbraco.cms.businesslogic.packager.Installer.Import(String inputFile, Boolean deleteFile) at Umbraco.Web.Editors.PackageInstallController.PopulateFromPackageData(LocalPackageInstallModel model) at Umbraco.Web.Editors.PackageInstallController._7.MoveNext() --- End of stack trace from previous location where exception was thrown ---
    I am not able to understand what is the problem
    Please can anyone help me in fixing this. I have checked and verified all permissions are correct. I need to fix this at any cost.Need support urgently Thanks
  • AddWeb Solution Pvt. Ltd 109 posts 354 karma points
    Mar 29, 2019 @ 05:28
    Hi, Dipanwita das
    The problem was that my web.config wasn't updated during installation - I found the info from this article:
    http://our.umbraco.org/projects/website-utilities/ucommerce/ucommerce-support/32993-Install-Problem-Un-Install-Problem
    "Turns out that the app pool identity did not have permissions to create new files. uCommerce needs this during install because it backs up any files it needs to modify before doing so. This includes web.config."
    I manually merged the uCommerce.config with my web.config and everything works now.
