Hi i got the examine search working, really impressive, but i have following problem:
When i use a OR it never hits on the second part
float y = 0.1f;var query = sc.Field("Postcode", searchtext.Text.Fuzzy(y)).Or().Field("Adres", searchtext.Text.Fuzzy(y));
Can someone explain me what i am doing wrong?
Just found out that i had to set the BooleanOperation to Or
var sc = ExamineManager.Instance.CreateSearchCriteria(IndexType.Content,Examine.SearchCriteria.BooleanOperation.Or);
Correct, you need to specify that the default operation is a Boolean of Or (Default is And).
You can view the Lucene query by doing a ToString on your ISearchCriteria object
Upload image
Examine search, problem with OR
float y = 0.1f;
