  • Olov 27 posts 101 karma points
    Jul 01, 2010 @ 11:08
    Olov
    Problems with DataProvider.Load<T>()
    After working with another CMS a lot something I was missing when i started an Umbraco project a few days ago was a CurrentPage property. So I created a base class for my masterpages that exposes that property, when leaving the office yesterday running 4.1 RC it was working but when catching up with my RSS last night i noticed that 4.5 is released so I upgraded it this morning and it stopped working... :(
    Each masterpage class looks like this:
    public partial class Startpage : Foo.Web.UI.MasterPage<Foo.Startpage> {
    And the MasterPage<T> base class looks like this:
    public class MasterPage<T> : System.Web.UI.MasterPage where T : DocTypeBase, new()
            public T CurrentPage
                get
                    int nodeId = Node.GetCurrent().Id;
                    return FooDataContext.Instance.GetPage<T>(nodeId);
    The FooDataContext.Instance is picked from the video by Aaron Powell here: http://vimeo.com/9790069 and looks like this:
            public static FooDataContext Instance {
                get
                    var ctx = HttpContext.Current.Items["FooDataContext"] as EoslDataContext;
                    if (ctx == null)
                        ctx = new FooDataContext();
                        HttpContext.Current.Items["FooDataContext"] = ctx;
                    return ctx;
    When I access any property on CurrentPage it throws this exception (Stack trace):
    [ArgumentNullException: Value cannot be null.
    Parameter name: attribute]
    System.Xml.Linq.XAttribute.op_Explicit(XAttribute attribute) +90598
    umbraco.Linq.Core.Node.<>c__DisplayClass1`1.<Load>b__0(XElement d) +76
    System.Linq.Enumerable.SingleOrDefault(IEnumerable`1 source, Func`2 predicate) +172
    umbraco.Linq.Core.Node.NodeDataProvider.Load(Int32 id) +250
    Foo.Web.Masterpages.Startpage.OnLoad(EventArgs e) in C:\projects\foo\Foo.Web\Masterpages\Startpage.Master.cs:17
    System.Web.UI.Control.LoadRecursive() +74
    System.Web.UI.Control.LoadRecursive() +146
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
    Am I missing something obvious?
    Jul 01, 2010 @ 11:11
    Olov
    I'm unable to edit my post, the CurrentPage property looks like this:
    get
    return FooDataContext.Instance.DataProvider.Load(nodeId);
    And the relevant part of the stack trace for accessing a property on CurrentPage is this:
    umbraco.Linq.Core.Node.NodeDataProvider.Load(Int32 id) +252
    Jul 01, 2010 @ 12:08
    Olov
    Solved my own problem by creating an method instead of Load<T>(), GetPage<T>() that seems to be working:
    public T GetPage<T>(int nodeId) where T : DocTypeBase, new()
        return FooDataContext.Instance.LoadTree<T>().Where(x => x.Id == nodeId).FirstOrDefault();
    But still it's confusing that Load<T>() doesn't work...
  • Aaron Powell 1708 posts 3046 karma points c-trib
    Jul 01, 2010 @ 14:04
    Aaron Powell
    Well I never anticipated this usage for LINQ to Umbraco, and if you're trying to use Load<T> you'll loose a lot in performance (it doesn't work with the cache).
    Jul 01, 2010 @ 14:09
    Olov
    So whats the recommended way to get a strongly typed "CurrentPage" ?
    Jul 01, 2010 @ 14:21
    Aaron Powell
    There isn't. LINQ to Umbraco doesn't have a concept of 'current page', it doesn't understand hierarchy. That's now how it's designed.
    Jul 01, 2010 @ 14:38
    Olov
    What about caching the data inside the getter of CurrentPage and listen to Document.BeforeSave, Document.BeforeMove etc and clear the cache on those events?
