  • Walter E. Harms 13 posts 33 karma points
    Aug 02, 2010 @ 16:52
    Walter E. Harms
    Setting rights on node.. problem with publish
    I've the following problem. I want to create a node from a usercontrol and i want only one membergroup to have access to it.
    It all seems to work right until the user logs off (or a IIS reset is performed), after that the node is not accesable until a republish entire node is performed.
    here is the code i'm using
                Document doc = NodeLevel.CreateNode(txtFolderName.Text, "Folder" , nodeId);
                doc.getProperty("naam").Value = txtFolderName.Text;
                doc.getProperty("omschrijving").Value = txtDescription.Text;
                Access.ProtectPage(false, nodeId, loginPage, errorPage);
                Access.AddMembershipRoleToDocument(nodeId, "groupName");
                doc.Publish(User.GetUser(0));
                umbraco.library.UpdateDocumentCache(doc.Id);
                umbraco.cms.businesslogic.web.Document.RePublishAll();
                umbraco.library.RefreshContent();
    actually my question is how to perform a republish entire site from code, or how to apply the security part in a right way.
    thanks for any suggestions.
    gr. Walter
    Aug 02, 2010 @ 16:53
    Walter E. Harms
    oeps... version 4.5
    Aug 02, 2010 @ 17:21
    Ismail Mayat
    Walter,
    Does it work when you manually set the permission on the page?
    Regards
    Ismail
  • Thomas.R 39 posts 62 karma points
    Aug 02, 2010 @ 18:03
    Thomas.R
    umbraco.library.RefreshContent() does not already republish the entire site ?
  • Sascha Wolter 615 posts 1101 karma points
    Aug 02, 2010 @ 18:17
    Sascha Wolter
    Have you tried doc.XmlGenerate(new XmlDocument); ?
    Aug 02, 2010 @ 19:44
    Walter E. Harms
    Hi All,
    Thanks for your suggestions, @ismail, yes when setting permissions manual it all seems to go well.
    After a little investigation the source code of umbraco it seems that
     umbraco.content.Instance.RefreshContentFromDatabaseAsync();
    is called on republish entired site, and... It solved my problem. I'm not quitte sure what is does, but will try to find out that after finishing this site.
    gr. Walter
