  • Bharath 40 posts 62 karma points
    Sep 18, 2010 @ 10:58
    Bharath
    LinqToUmbraco in console application. Need help.
    Need help... on LinqToUmbraco without a WebContext...
    I have a console app that need to use LinqToUmbraco generated Entities.
    CmsDataContext class that generated from the "Export to .Net" umbraco DocumentTypes .
    What i did...
    static void Main(string[] args)
                       using (var dataProvider = new NodeDataProvider("umbraco.config", true))
                using (var ctx = new CmsDataContext(dataProvider))
                    var latestPost = (from post in ctx.BlogPostDTs
                                      orderby post.UpdateDate descending
                                      select post).First();
    RECEIVING following ERROR. Please suggest what i am doing wrong???
    System.TypeInitializationException was unhandled
      Message="The type initializer for 'umbraco.UmbracoSettings' threw an exception."
      Source="businesslogic"
      TypeName="umbraco.UmbracoSettings"
      StackTrace:
           at umbraco.UmbracoSettings.get_ForceSafeAliases()
           at umbraco.cms.helpers.Casing.SafeAliasWithForcingCheck(String alias)
           at umbraco.Linq.Core.Node.NodeDataProvider.LoadFromXml[T](XElement xml, T node)
           at umbraco.Linq.Core.Node.NodeTree`1.GetEnumerator()
           at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
           at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__0.MoveNext()
           at System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
           at EvaluateLinqToUmbracoConsoleApp.Program.Main(String[] args) in G:\Bharath\umbraco\EvaluateLinqToUmbracoConsoleApp\Program.cs:line 20
           at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
           at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
           at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
           at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
           at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
           at System.Threading.ThreadHelper.ThreadStart()
      InnerException: System.ArgumentNullException
           Message="Value cannot be null.\r\nParameter name: str"
           Source="mscorlib"
           ParamName="str"
           StackTrace:
                at System.Security.Permissions.FileIOPermission.HasIllegalCharacters(String[] str)
                at System.Security.Permissions.FileIOPermission.AddPathList(FileIOPermissionAccess access, AccessControlActions control, String[] pathListOrig, Boolean checkForDuplicates, Boolean needFullPath, Boolean copyPathList)
                at System.Security.Permissions.FileIOPermission..ctor(FileIOPermissionAccess access, String path)
                at System.Web.InternalSecurityPermissions.get_AppPathDiscovery()
                at System.Web.HttpRuntime.get_AppDomainAppPath()
                at umbraco.GlobalSettings.get_FullpathToRoot()
                at umbraco.UmbracoSettings..cctor()
           InnerException:
  • Aaron Powell 1708 posts 3046 karma points c-trib
    Sep 18, 2010 @ 13:05
    Aaron Powell
    LINQ to Umbraco doesn't work in a console application due to the way it needs to resolve the aliases of the nodes.
