  • Ron G 41 posts 137 karma points
    Oct 10, 2010 @ 21:23
    Ron G
    Custom Section Edit Page - Using a DataTimePicker
    I'm trying to include a dateTimePicker on my custom edit page. I am able to get it working using:
    <%@ Page Language="C#" MasterPageFile="~/umbraco/masterpages/umbracoPage.Master" AutoEventWireup="true" CodeBehind="editCustom.aspx.cs" Inherits="UmbracoCustomTest.editCustom" %>
    <%@ Register TagPrefix="cc1" Namespace="umbraco.uicontrols" Assembly="controls" %>
    <%@ Register TagPrefix="cc2" Namespace="umbraco.uicontrols.DatePicker" Assembly="controls" %>
    <cc1:PropertyPanel id="PPanel" runat="server" Text="Date">
         <cc2:DateTimePicker id="theDate" runat="server" />
    </cc1:PropertyPanel>
    The problem is I cannot assign a value to the DateTimePicker control on Page Load / Not IsPostBack because the .Text property is read-only. What is the right way to assign a value to this control when the edit page is loaded?
    Thank you!
    Oct 10, 2010 @ 21:36
    Ron G
    Of course, 2 seconds after I post the question, I find the answer.
    // Assign a value to the DateTimePicker
    theDate.DateTime = DateTime.Now
    // Retrieve the value from the DateTimePicker
    DateTime myDateTime;
    myDateTime = theDate.DateTime;
    // Only do date and not time
    theDate.ShowTime = false;
    Hopes this helps someone in the future.
  • Max 144 posts 166 karma points
    May 15, 2012 @ 10:16
    Max
    i tried it but the desighner is nto geneared in aspx.desighner.cs file
    any ideas why ??
  • Jignesh 31 posts 51 karma points
    May 31, 2012 @ 15:32
    Jignesh
    I got umbraco source code and then change in DateTimePicker class..
    there is only get property of Text so i just put Set property
    then just update controls.dll its working fine...
    Jignesh Ramavat
    May 31, 2012 @ 15:34
