What to do with an Umbraco Project after downloading it
I just got started with Umbraco and I'm wanting to use a Project I found for putting flash videos on a webpage. I downloaded the Project, but I don't know what to do with the files now. There are 4 files. A js file, an xml file, a swf file (for the flash player), and an xslt file. What am I supposed to do so I can start using this macro/project?
I think you're just not familiar with the basics yet, I can really recommend you have a look at the free introduction videos. Things should make much more sense after that!
Installing Umbraco on localhost:
http://our.umbraco.org/wiki/install-and-setup/installing-umbraco-4-on-localhost
If you have any question, please feel free to contact me at emacho@be-computed.com
Regards,
Eduardo
