  • Christo 23 posts 44 karma points
    Nov 25, 2010 @ 12:22
    Christo
    Document.MakeNew and problem with caching
    Hi guys,
    we experience some caching problems while creating new documents via API. Let me explain the szenario:
    1.we check if a document exists(via LINQ)
    2. if not we wil create the new document via Document.MakeNew and Publish() it and UpdateDocumentCache() as well
    when we then check again if the document exists (step 1. ) via LINQ we still receive a false even though the doc is definetly there. so at some point the cache is still active. I'm not quite sure if this is a common API issue or a LINQ issue. Or is there another method to force clearing the cache.
    in umbracosttings.config we've set ContinouslyUpdateXmlDiskCache to true btw.
    Any ideas? I appreciate your help
    Christo
    PS:we use 4.5.2
  • Eduardo 106 posts 130 karma points
    Nov 25, 2010 @ 12:37
    Eduardo
    Hi Christo,
    I had had the same problem but now is solved:
    Just add this two lines of code into the head section of your pages or masterpage:
    <meta http-equiv="pragma" content="no-cache" />
    <meta http-equiv="Cache-Control" content="no-cache, mustrevalidate" />
    Add to the web.config (under System.Web)
    <caching>
    <cache disableMemoryCollection = "true"
    disableExpiration = "false"
    privateBytesLimit = "0"
    percentagePhysicalMemoryUsedLimit = "20"
    privateBytesPollTime = "00:00:05"/>
    </caching>
    Hope this helps you too.
    Sincere regards,
    Eduardo Macho
    Nov 25, 2010 @ 15:37
    Christo
    Hi Eduardo,
    thanks for ths suggestion. The thing is - I don't even load a new page as such. I'm adding backend-side a new document and check if its there in the 2nd step(no requests/reload between the step 1 and 2.) and the API sais the new document is missing, but it is there and its published.
    So the Meta-Tags and the web.config are irrelevant in this case I'm afraid
    Cheers
    Nov 25, 2010 @ 15:49
    Eduardo
    Hi Christo,
    I made a mistake, that wasn't supposed to be here.
    Regards,
    Eduardo
    Nov 25, 2010 @ 16:06
    Eduardo
    Set ObjectTrackingEnabled property to false to prevent LINQ from caching data
    http://msdn.microsoft.com/es-es/library/system.data.linq.datacontext.objecttrackingenabled.aspx
    Or consider using umbraco SQLHelper DataReader
    IRecordsReader reader = Application.SqlHelper.ExecuteReader(@"");
    I use datareaders.
    The code you are running is ok.
    HTH.
    Sincere regards,
    Eduardo
  • Manos Gatsios 21 posts 41 karma points
    Jan 26, 2011 @ 19:03
    Manos Gatsios
    Hi Christo,
    Recently I had exactly the same situation as you did and after some testing and debugging I discovered that the Document.Children collection (which is probably what the LINQ call is using) is not updated to reflect any newly added children (via a Document.MakeNew() ).
    Instead of iterating through the list of children, try using the Document.GetChildrenBySearch( parent_id, child_name ) instead.
    Assuming you know the name of the document you are looking for (and most probably you do) then calling this method will have the expected outcome.
    I hope this helps.
    Regards
    Manos
