So, it seems to me, that I have to implement my own membership provider when I wan't to have more than one member type working with the UmbracoMembershipProvider. I have tried this, but I'm having some trouble getting all the way through.
In Umbraco I have created a member type called, lets say, NewMemberType. I added a new membership provider in the web.config as so:
Now, using Reflector, I know, that UmbracoMembershipProvider.CreateUser() at some point calls the Member.MakeNew() function with the value of this.m_DefaultMemberTypeAlias as the member type.
My guess it that the member type isn't found and null is returned in the MemberType.GetByAlias() method, causing the final Content.CreateContent() method to fail.
So, I know I have a missing link somewhere, I just can't put my head around where. Heck, I might even be on the wrong track but any help would be highly appreciated!!
var provider = (NewMembershipProvider)Membership.Providers["NewMembershipProvider"];
But I guess you found the missing link, much appreciated!
Eduardo, I do very much intend on creating members. The CreateUser() method might confuse what my intentions are, but it does actually create members and not users :)
I probably wouldn't bother casting it to be honest, unless you have some specific methods you've also defined on it, that way if you ever do want to switch it out, it's just a case of changing web.config, where as right now you'd also have to change the cast and rebuild.
Custom membership provider problem
<add name="NewMembershipProvider"
type="project.MembershipProviders.NewMembershipProvider"
defaultMemberTypeAlias="NewMemberType"
enablePasswordRetrieval="false"
enablePasswordReset="false"
requiresQuestionAndAnswer="false"
passwordFormat="Hashed"/>
I then implemented the new very basic membership provider, as so:
namespace project.MembershipProviders
public class NewMembershipProvider : umbraco.providers.members.UmbracoMembershipProvider
public MembershipUser CreateUser(string username, string password, string email)
MembershipCreateStatus status;
return CreateUser(username, password, email, null, null, true, out status);
public MembershipUser CreateUser(string username, string password, string email, string passwordQuestion, string passwordAnswer, bool isApproved, out MembershipCreateStatus status)
return CreateUser(username, password, email, passwordQuestion, passwordAnswer, isApproved,
null, out status);
public MembershipUser CreateUser(string username, string password, string email, string passwordQuestion, string passwordAnswer, bool isApproved, object providerUserKey, out MembershipCreateStatus status)
return base.CreateUser(username, password, email, passwordQuestion, passwordAnswer,
isApproved, providerUserKey, out status);
Now, when I try to create a member using the following code:
var provider = new project.MembershipProviders.NewMembershipProvider();
var member = provider.CreateUser("mads.krohn", "tester", "mail@sniff.dk");
I get a NullReferenceException. Following is a part of the callstack:
umbraco.cms.businesslogic.Content.CreateContent(ContentType ct) +188
umbraco.cms.businesslogic.member.Member.MakeNew(String Name, String LoginName, String Email, MemberType mbt, User u) +662
umbraco.cms.businesslogic.member.Member.MakeNew(String Name, String Email, MemberType mbt, User u) +55
umbraco.providers.members.UmbracoMembershipProvider.CreateUser(String username, String password, String email, String passwordQuestion, String passwordAnswer, Boolean isApproved, Object providerUserKey, MembershipCreateStatus& status)
project.MembershipProviders.NewMembershipProvider.CreateUser(String username, String password, String email, String passwordQuestion, String passwordAnswer, Boolean isApproved, Object providerUserKey, MembershipCreateStatus& status)
project.MembershipProviders.NewMembershipProvider.CreateUser(String username, String password, String email, String passwordQuestion, String passwordAnswer, Boolean isApproved, MembershipCreateStatus& status)
project.MembershipProviders.NewMembershipProvider.CreateUser(String username, String password, String email)
Kind regards,
Mads
Hey Mads,
Have you tried referencing the Membership provider from the providers collection?
I'm not sure whether instantiated the class yourself if not passing in the config values?
Matt
Hi Mads,
I remind you that a user is not a member.
User = BackEnd user.
Member = FrontEnd user.
What do you want to do? Create new users o members?
Sincere regards,
Eduardo Macho
Thank you Matt, that did the trick!
I'm actually casting it as so:
Cool,
Just a thought =)
Matt
Point taken! Thanks again! :)
Hi Mads,
Glad to see the problem is solved :)
Sincere regards,
Eduardo Macho
