  • Ian Banks 24 posts 44 karma points
    Dec 16, 2010 @ 16:35
    Ian Banks
    Load Balancing problem
    I have an Umbraco site which is in a load balanced environment, there seems to be an issue whereby the site is extreamly slow there seems to be this error which is a recuring thing has anyone else had this problem before?
    Ian
    Error refreshing a node in the distributed list: 'System.Net.WebException: The request failed with HTTP status 400: Bad Request.     at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)     at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)     at umbraco.presentation.cache.CacheRefresher.EndRefreshById(IAsyncResult asyncResult)     at umbraco.presentation.cache.dispatcher.InvokeDispatchMethod(DispatchType dispatchType, Guid factoryGuid, Int32 numericId, Guid guidId)', URI attempted: http://wgb01lb7002:8886/umbraco/webservices/cacheRefresher.asmx umbraco
