  • webmonger 130 posts 285 karma points
    Jan 13, 2011 @ 15:44
    webmonger
    Parse XML through XSLT Engine in /base
    I'm looking to parse some XML through the Umbraco XSLT engine from a .net class thats accessed via the /base rest interface.
    So far i've tried using
    umbraco.library.RenderMacroContent(@"<umbraco:Macro Alias='macroalias' runat='server'></umbraco:Macro>",id)
    but this just re-renders the <umbraco:macro~> code
    Is there an easy way to access the XSLT Macro Engine via the API?
    Cheers
    Jon
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Jan 13, 2011 @ 15:56
    Douglas Robar
    Looks like you need some escaping, and the old v3 syntax.
    Check http://en.wikibooks.org/wiki/Umbraco/Reference/umbraco.library/RenderMacroContent for details.
    cheers,
    doug.
    Jan 13, 2011 @ 16:04
    webmonger
    Hi Doug
    Thanks for the speedy reply. Just tested the old v3 code and it's still just rendering the content I placed to be converted. e.g
    umbraco.library.RenderMacroContent("&lt;?UMBRACO_MACRO macroAlias=&quot;macroalias&quot; &gt;&lt;/?UMBRACO_MACRO&gt;", id);
    This just renders "<?UMBRACO_MACRO macroAlias="macroalias" ></?UMBRACO_MACRO>
    Curious!
    Jon
  • Matt Brailsford 4125 posts 22223 karma points MVP 9x c-trib
    Jan 13, 2011 @ 16:14
    Matt Brailsford
    Hey Jon.
    Have you tried UN escaping the special characters, as I have the feeling they only recommend encoding them as documentation assumes you are calling the method from XSLT, which would require them to be escaped, but you are calling it from code.
    umbraco.library.RenderMacroContent("<?UMBRACO_MACRO macroAlias=\"macroalias\" ></?UMBRACO_MACRO>", id);
    Matt
    Jan 13, 2011 @ 16:26
    webmonger
    Spot on Matt. That worked perfectly. Now i just need to work out how to get currentPage working ;)
    Cheers
    Jan 13, 2011 @ 16:31
    Douglas Robar
    Ah yes, of course. Thanks, Matt. What a team! :)
    cheers,
    doug.
    Jan 13, 2011 @ 16:38
    Just for information I took the liberty to copy the content from the old reference into the new reference here on our. Then information can now be found at http://our.umbraco.org/wiki/reference/umbracolibrary/rendermacrocontent also. (Asuming that some day the old umbraco wiki site will no longer be around)...
    Jan 13, 2011 @ 16:40
    Matt Brailsford
    @Jon no problem
    @Doug Absolutley! #h5wr
    Jan 13, 2011 @ 16:59
    webmonger
    @Jan - Good idea. I had seen that wikibooks post but ignored it as it was very old. Having it in the wiki validates its uses again for me. Cheers
