  • Kurniawan Kurniawan 202 posts 225 karma points
    Feb 02, 2011 @ 09:16
    Kurniawan Kurniawan
    Datepicker datatype doesn't work with "mandatory" checkbox
    I have the problem where Datepicker datatype doesn't respect "mandatory" checkbox
    And I saw this bug link, http://umbraco.codeplex.com/workitem/28646
    It seems it has been fixed.
    But Do you know how to get this fixes ?
    My current version is umbraco v 4.5.2 (Assembly version: 1.0.3891.20719)
    What should I do to get this fixes ?
    Thanks for your help.
    Feb 02, 2011 @ 09:27
    I don't know if it's an option for you to upgrade to 4.6.1?
    Otherwise I think you need to look in the changeset here http://umbraco.codeplex.com/SourceControl/list/changesets - but I must admit I don't know much about how to do this and I don't know if the changeset with the above fix is still available.
  • Jakob Jensen 23 posts 43 karma points
    Feb 02, 2011 @ 12:28
    Jakob Jensen
    The bug is fixed in 4.6.1
  • Seth Niemuth 275 posts 397 karma points
    Feb 02, 2011 @ 12:48
    Seth Niemuth
    If you can't/don't want to upgrade you may be able to add a regular expression to make it mandatory. I remember on version 3, I needed to make a date mandatory and it didn't work and so I used a regular expression:
    http://forum.umbraco.org/yaf_postst5005_Mandatory-Datepicker.aspx
    Feb 03, 2011 @ 00:04
    Kurniawan Kurniawan
    Thanks Guys,
    But I have tried to put a regular expression but it just ignore it.
    At this moment, I can't really upgrade, But may be I can write my own umbraco data type (datePicker)
    Is there any pointer where can I create my own data type which store date time ?
