  • Prasad joshi 35 posts 55 karma points
    Feb 11, 2011 @ 11:38
    Prasad joshi
    css property problem
    hi,
    I am create the property of css by .somename and want to give in richtext editor but it cant work
    plz help me out
    Feb 11, 2011 @ 12:35
    Feb 11, 2011 @ 12:55
    Prasad joshi
    Yha i Read this but still it not apply...
    Feb 11, 2011 @ 12:59
    Dirk De Grave
    Also need to make sure stylesheet can be used in the rte. Go to datatype settings of your rich text editor datatype, check relevant stylesheet and all should work well
    /Dirk
    Feb 11, 2011 @ 13:16
    Prasad joshi
    In the datatype i choose my style sheet in which i create the property but still it not work
    Feb 11, 2011 @ 13:22
    Hi Prasad
    could you give bit more information about HOW it's not working? You can see the defined style in the "styles" dropdown in the rich text editor? If so, is it when you apply the style to some text that it does not work?
    Feb 11, 2011 @ 13:46
    Prasad joshi
    yha ..
    I create the style sheet and then its property name as .para. Now i goes in content write the text in the rte and just select the style property in the dropdown list but it cant reflect in the editor not even in page.
    Feb 11, 2011 @ 13:50
    Hi Prasad
    If you use the "HTML" view button in the RTE, is the style class then applied to the element directly or wrapped with a <span class="yourstyle"></span> kind of way?
    I think this could maybe have something to do with CSS specificity...
    Feb 11, 2011 @ 13:54
    Prasad joshi
    no class is applied in rte
    Feb 11, 2011 @ 13:56
    Hi Prasad
    How have you defined the style in the stylesheet?
    What have you written in the different fields?
    Alias: ?
    Style: ?
    Feb 11, 2011 @ 14:06
    Prasad joshi
    Alise :.para
    style :color:#ac0404; font-family:"Lucida Sans Unicode", "Lucida Grande", sans-serif; font-size:16px; text-decoration:underline; padding-left:50px; margin-top:20px;
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Feb 11, 2011 @ 15:21
    Michael Latouche
    Hi Prasad,
    Are you trying to apply the style on simple texte, or is it on a html element like a link or something? Because I think the RTE is by default configured in a way that not all element/tags are allowed to have a class attribute defined.
    Also - just to make sure :-) : do you actually select/highlight the text to format prior to selecting the style in the list?
    Michael.
