I've got a macro with a .net usercontrol that renders child nodes and a rich-text-editor property from each of them. Inside these rich-text-editor properties there might be a macro. Anyway to render that inner macro? Now the output of the inner macro is just blank...
I think to process the macros embedded within a rich-text-editor, you'll have to search for the Macro delimiter <?UMBRACO_MACRO macroAlias="..." /> within the rich-text-editor property and then dynamically add it.
I also have to search for each and one of the macro parameters I suppose. They aren't stored in the database somehow? To bad my regex skills sucks.... :p
Render macro inside another macro. Possible?
Stig
stig,
It is possible to call xslt macro from xslt macro using RenderMacro xslt extension method but i am fairly certain you cannot do it from .net macro
Regards
Ismail
Hi Stig
You can call a .Net macro and an XSLT macro from a .Net macro (see Tim's blog post on Adding an Umbraco macro dynamically to a user control), but can only call XSLT macros from other XSLT macros (see the RenderMacroContent wiki page)
HTH,
Hendy
Great! Thanks alot!
