  • PCharb 22 posts 42 karma points
    Apr 11, 2011 @ 18:13
    PCharb
    Need help for content channel
    Hi, i've got some problems with the content channel. I want to add data in the wod document,
    Author, esspecially, because i've multiple user of the publish with word and I don't wantto
    have like 10 user on my site. Can we change some property of the content channels or add other property??
    Apr 11, 2011 @ 20:03
    Hi PCharb
    I'm not sure what it is you're asking here?
    Do you need your authors to all be able to update content using Word or do you need to get the author name on the created nodes in Umbraco (When they create content through word)?
    Apr 11, 2011 @ 20:38
    PCharb
    The problem is that when you log on as an umbraco user with word, it's works fine, but when i get the author name, i have the user that i use for my content channel. What i want is that the people who write the blog post with word add his name in xml data of word document an then i can't take it to publish the news. I don't know if you can help me?
    Apr 14, 2011 @ 20:36
    PCharb
    it's ok i've did something else with a razor script.
