  • Petras Surna 90 posts 144 karma points
    Apr 14, 2011 @ 04:39
    Petras Surna
    /home/ doesn't work, /home does, why?
    I am using @umbraco.library.NiceUrl(@Id) to create URLs. The URLs it creates end with a /
    eg http://www.activia.com.au/activia-products/
    However, the ending / is not working for the Home page
    http://www.activia.com.au/Home/ doesn't work whilst
    does.
    How can I get http://www.activia.com.au/Home/ to work?
    Apr 14, 2011 @ 08:15
    Hi Petras
    Is the umbracoUseDirectoryUrls set to true in the web.config file? (In the appSettings section).
  • Daniel Bardi 927 posts 2562 karma points
    Apr 14, 2011 @ 08:33
    Daniel Bardi
    the umbracoSettings.config has an option to remove the trailing slash '/' from urls.. I'd recommend you give that a try.
    Apr 14, 2011 @ 08:44
    Petras Surna
    I tried modifying
    <addTrailingSlash>false</addTrailingSlash>
    But that doesn't seem to do anything.
  • Ove Andersen 435 posts 1541 karma points c-trib
    Apr 14, 2011 @ 09:00
    Ove Andersen
    Is there any other url rewriting rules in your web.config?
    Look for an <urlrewrite> tag and see if there is anything there related to your home page.
    Apr 14, 2011 @ 09:10
    Petras Surna
    There are no rewriting rules.
    I can't see that tag in web.config or any other config.
    BTW, this is a 4.7 install.
    Apr 14, 2011 @ 09:33
    Ove Andersen
    It means you don't have any iis rewrite rules messing stuff up. :)
    What's also weird, the adress http://www.activia.com.au/home/home/home also points to /home...
    Do you have a template with the alias "home"?
    Apr 14, 2011 @ 09:48
    Hi Petras
    I've tried to see if I could edit your post where you post the content from your web.config. Ufortunately I can't - So therefore I would urge yourself to do it, to remove the part with your connection string.
    If you can't edit it either, is it ok if I delete it then? Credentials are on display, which for your own safety's sake they should not be.
    Apr 14, 2011 @ 09:55
    Hi Petras
    I deleted the post with your appSettings due to security concerns on your behalf. I hope your ok with that.
    When you copy/paste stuff from the web.config please make sure your credentials are not being displayed for the whole world to see :-)
    To sum it up shortly for those who want to help you out: umbracoUseDirectoryUrls IS set to true in the appSettings.
    Apr 14, 2011 @ 10:02
    Petras Surna
    The password in web.config does not work but the post has been removed anyway by Jan. Thanks for that.
    Yes, I do have a template with the alias "Home".
    Apr 14, 2011 @ 10:11
    Hi Petras
    Ok, but I better like to be safe than sorry :-)
    Apr 14, 2011 @ 12:10
    Ove Andersen
    Could you try to rename that template to for example "HomePage"?
    Apr 15, 2011 @ 03:39
    Petras Surna
    I tried this and it worked!
    Then I renamed it back to Home and for some reason the trailing slashes have disappeared.
    It's as though <addTrailingSlash>false</addTrailingSlash> suddenly kicked in.
    I was pretty sure I republished the site after adding it last time.
    I am going to use <addTrailingSlash>false</addTrailingSlash> as a standard from now on.
