When I create documents programatically, strings that contain special characters are saved as ( for example. ö or ") How can come around this problem?
It is displayed as above in the umbraco content section after creating a umbraco.cms.businesslogic.web.document....how can I set encoding so that it accepts characters like (å,ä,ö,") etc?
Depending on your version of Visual Studio you should be able to go to "File -> Save selected item as"...and from the window that appears here you should be able to select the encoding.
There something I do not quite understand in your code snippet: it seems you call the .Replace method on one of your product properties, without assigning the result to any variable. So in fact this does not do anything concrete I think. Then you assign product.description to your DescriptionLabel, but from what I see in the code, product.description was not changed.
Have you tried something like this:
var description = product.GetProperty(reqProperty).Value.ToString().Replace("\n","<br/>"); DescriptionLabel.Text = description;
Or maybe you will need to HtmlDecode or something.
Sorry for me not understanding correctly, I can imagine you cannot post your full code ;-), but I still do not see the link between the different pieces of code you have posted :-S
If you want to display the product description property which is multi-line, then I guess you must use something like this :
If you want to use the result of your productInfo method, then I guess you must use something like this:
var description = productInfo("123456", "description", product); DescriptionLabel.Text = Server.HtmlDecode(description.Replace("\n","<br/>")); // or do the Replace within yout productInfo method "else" branch
But for the moment, I do not see the link, in your example/problem, between the productInfo method and the fact that you assign the product.description property to the literal. Can you maybe post a little more info to make that link become clear?
Also, I am actually not sure if you need to HtmlDecode, but I am quite sure that HtmlEncode is of no use in this case. HtmlEncoding will replace your "<br/>" to something like "<br/>".
Problems with text
Hi Frederik
What kind of characters are you creating? And where is it displayed as above?
Are you saving the the file encoded as utf-8?
Hope this helps.
Problem was solved by using a Html Decode method when the property value was set
I have another similiar problem.
When writing text in a textbox multiple, the linebreaks dissapears when adding the property value to a string in visualstudio.
Is there away to output the property value of type 'textbox multiple' through an aspx usercontrol without the linebreaks disappearing?
Hi Fred,
I guess you can do a .Replace("\r\n"n "<br/>") on the property value, or something similar?
Michael.
I have tried various ways of achieving this without any luck.
Critical parts from my code as it looks like right now.
DescriptionLabel.Text = product.description;
DescriptionLabel is asp:literal and ive tried with all modes(transform, pass through and encode).
Replace does find and replace \n but only show <br/> as text in the output
Hi Fredrik,
var description = product.GetProperty(reqProperty).Value.ToString().Replace("\n","<br/>");DescriptionLabel.Text = description;
Hope this helps.
Michael.
Well it actually looks like this:
So it is not the complete code :). The problem lies somewhere in what in my last entry...
Ive tried html.decode and encode like:
DescriptionLabel.Text = Server:HtmlEncode(product.description);
Hi Fredrik,
var description = productInfo("123456", "description", product);DescriptionLabel.Text = Server.HtmlDecode(description.Replace("\n","<br/>")); // or do the Replace within yout productInfo method "else" branch
Michael.
