  • Jenny Meyer 1 post 21 karma points
    Aug 15, 2011 @ 16:34
    Jenny Meyer
    Problem with asp:LoginName
    i am new with Umbraco and have a problem to show the Membername of the logged in Member:
     <asp:LoginView ID="LoginView1" runat="server">
                    <AnonymousTemplate>
                        <asp:Login ID="Login1" runat="server" > </asp:Login>
                    </AnonymousTemplate>
                    <LoggedInTemplate>
                      Logged in as <br>
                      <asp:LoginName ID="LoginName1" runtat="server" /><br>
                      <asp:LoginStatus ID="LoginStatus1" LoginText="Login" LogoutText="Logout"  LogoutPageUrl="/default.aspx" LogoutAction="Redirect" runat="server" />
                    </LoggedInTemplate>
                  </asp:LoginView>
    the login status works fine, but i not see the LoginName of the User.
    I am using Version 4.7.0 and use RoleBased authenication.
    is the asp:LoginName not supported in V4.7.0?
    is there an other way to get the Membername and aditional infos of the member?
    thanks for help in advance
    Jenny
