This works fine for changing from related document back to the origninal document (where it has been copied from) but in the other way it does not work.
I am having this exact same problem! Just posted twice on it. It seems that the original document always has an absolute link instead of a relative one. Haven't found a way around this. Did you solve it?\
Try to install the relation package which enables you to see the relation in the content. On my site the problem was that there were two relation for this content. If you install this plugin you can simply delete the wrong relation and than it will work
GetRelatedNodesAsXml problem
I am using the language dropdown XSLT script.
Heres is my script:
//Garrett
Hi Garret,
