  • Stefan Ekman 18 posts 37 karma points
    Sep 28, 2011 @ 18:07
    Stefan Ekman
    Custom Macro parameter with dropdown with values from DB
    Found some similar questions but they are quite old and not any very clear answers so here I go..
    I have a UserControl and created a Macro for it and all works fine. Now I want to extend it so when I add the Macro to a page I want a DropDown box with values from a table to select from which will set a public parameter for the usercontrol.
    I'm subscribing to the Umbraco Video's so if this is done here please tell me or if anyone knows the steps to do this?
    Stefan
  • Nigel Wilson 945 posts 2077 karma points
    Sep 28, 2011 @ 19:28
    Nigel Wilson
    Hi Stefan
    http://www.richardsoeteman.net/2010/01/04/CreateACustomMacroParameterType.aspx is a great blog post that I have referenced previously when adding a custom macro parameter.
    Mine was a simple dropdown list for image alignment (left or right) but it worked first time when referencing the above post.
    HTH
    Nigel
    Sep 28, 2011 @ 20:45
    Stefan Ekman
    Very nice and simple solution!
    I have worked with a few different CMS systems and won't look back! :)
