  • Thor Østergaard 37 posts 58 karma points
    Oct 09, 2011 @ 14:44
    Thor Østergaard
    Login/postback problem with usercontrol
    I'm having a 4.7.0 site with a few pages behind role membership control - that seems to work as it should.
    But on one of these pages I have a usercontrol with a few controls on it. Some of these controls cause autopostback and that work as expected, but when I click a button on the page causing a postback I'm send to the login page instead of the current page.
    I don't know where to look - the same usercontol works fine on my local computer.
    I have tried to remove the role security on the pages and put it back on (only on the top level) but that didn't help.
    Any suggestions?
  • Markus Johansson 1945 posts 5899 karma points MVP 3x c-trib
    Oct 10, 2011 @ 08:25
    Markus Johansson
    Its sounds a lite like this may be caused by multiple from-tags on the page? Or could this be related to your earlier posts about logout/cache-problems? http://our.umbraco.org/forum/developers/api-questions/24742-MemberGetCurrentMember()Id-getting-the-wrong-member
    Oct 10, 2011 @ 10:07
    Thor Østergaard
    Nope - there are only one form-tag on the page, but you might be right about the login case.
    I will try upgrade the site and see if it solve this problem.
    Oct 12, 2011 @ 12:33
    Thor Østergaard
    I have now upgraded to 4.7.1 but that didn't solve the problem :(
  • Michael Latouche 504 posts 819 karma points MVP 5x c-trib
    Oct 12, 2011 @ 13:22
    Michael Latouche
    Hi Thor,
    Do you get this behaviour for all buttons that cause a postback, or just on one particular? It this is just for one button, can you maybe give some indication of what it is doing?
    Michael.
    Oct 12, 2011 @ 13:24
    Thor Østergaard
    I think I the problem is the file management I do on postback - I'm investigating that now
