  • metalforgood 36 posts 55 karma points
    Oct 17, 2011 @ 18:08
    metalforgood
    Using langauge dictionary in asp.net control
    hi :) , i'm trying to make an asp.net control, that has an asp.net label, i want this label's text to be set according to the current language of the website,
    is there a way like label.text=umbraco.dictionaryitems.Getbyname("itemName");
    i know it's kinda fiction :D , but is there a way to set it automatically :)
    Oct 17, 2011 @ 18:15
    Tom Fulton
    Check out this post on Tim's blog, it explains how to use the dictionary items via umbraco.library:GetDictionaryItem("key"), and also has a method for setting the controls texts "automatically" - .net usercontrols and the umbraco dictionary
    Hope this helps,
    Tom
    Oct 17, 2011 @ 18:18
    metalforgood
    Hi tom, thank you, i tried this , but i don't know which library to refrence in order to use umbraco.library
    i refrenced cms, businesslogic, but there's no .library in umbrac :)
    Oct 17, 2011 @ 18:19
    Tom Fulton
    You should just need to reference umbraco.dll
    Oct 17, 2011 @ 18:30
    metalforgood
    every time i refrence the umbraco.dll
    the object can't be viewed in the object browser because it's not availble or not yet built please insure that the project is availble and built.
    sorry i know  i am bringing you a headache :)
    Oct 17, 2011 @ 18:55
    Tom Fulton
    Hmm, works for me.  Where are you getting this umbraco.dll from?  You should get it from the binaries download on codeplex - the same one that sits in the /bin/ folder of your website.
    Oct 17, 2011 @ 19:03
    metalforgood
    :( from the same source as you said, i don't know what's wrong with my visual studio :) .
    anyways thanks a lot for your help :)
    Oct 17, 2011 @ 19:15
    Tom Fulton
    Not really sure what else to try :/  never had that problem.
    Are you running VS2010?  And configured to use .NET 4?
    Oct 17, 2011 @ 19:17
    metalforgood
    nop visual studio 2008 , ahhhh it's .net 4, while visual studio 2008 is .net 3.5 :X  , thank you :D my bad , sorry :D
