  • Mike Taylor 155 posts 353 karma points
    Nov 16, 2011 @ 11:07
    Mike Taylor
    Stored procedures - retrieving output parameters using SqlHelper?
    I've added a couple of tables to my Umbraco database to store "orders" and "order lines" on a website. I've added a stored procedure to the DB which adds a new order, and returns the new order ID as an output parameter.
    What's the best way to run this stored procedure and retrieve the value of the output parameter? Is it possible to do with the Umbraco SqlHelper?
    Mike
    Nov 16, 2011 @ 12:00
    Jeroen Breuer
    The SqlHelper is nice to use in packages so it's compatible with all Umbraco installs, but for custom work I usually use ORM. I use LLBLGen for almost all our projects.
    Jeroen
    Nov 16, 2011 @ 12:27
    Mike Taylor
    Hi Jeroen - I'll definitely take a look at that, but for the project I'm working on, it's a bit overkill - I just need a couple of extra tables and a couple of stored procedures. Do you know if SqlHelper can manager output parameters?
    Mike
  • Richard Soeteman 4052 posts 12925 karma points MVP 2x
    Nov 16, 2011 @ 12:47
    Richard Soeteman
    Hi Mike,
    I don't think (pretty sure) this is not built in for the the SqlHelper. What you can do is use the normal SqlConnection/SqlCommand  objects then you can use output parameters.
    Richard
