  • Peter Drayton 29 posts 49 karma points
    Dec 21, 2011 @ 12:44
    Peter Drayton
    Using RenderMacroContent and MacroContainers on Umbraco v 4.7.1
    I am trying to use the RenderMacroContent on Umbraco v4.7.1 but it is not working:
    This is my code:
    <xsl:template match="/">
      <xsl:variable name="data" select="umbraco.library:GetXmlNodeById(1129)"/>
      <xsl:for-each select="$data">
        <xsl:value-of select="umbraco.library:RenderMacroContent(./sidebarModules, ./@id)" disable-output-escaping="yes"/>
      </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
    I have output the XML returned it is is correct, but has <?UMBRACO_MACRO macroAlias="Name" runat="server"></?UMBRACO_MACRO> and not <umbraco:Macro Alias="Name" runat="server"></umbraco:Macro>
    How do I get this working?
    Many thanks,
    Peter.
    Dec 21, 2011 @ 13:57
    Peter Drayton
    The XML returned is:
    <?UMBRACO_MACRO  macroalias="Macro1"  /><?UMBRACO_MACRO  macroalias="Macro2"  />
    So WHY is nothing output?
  • awm 187 posts 376 karma points
    Dec 21, 2011 @ 13:58
    awm
    shouldn't it have runat="server"?
    Dec 21, 2011 @ 14:53
    Peter Drayton
    It should, but that is what the XML is output as?
    Dec 21, 2011 @ 15:02
    Tom Fulton
    That looks correct.  Are these by chance .NET macros you are trying to render from XSLT?  If so unfortunately that is not supported, pretty sure you can only render XSLT Macros from XSLT.
    -Tom
    Dec 21, 2011 @ 15:18
    Peter Drayton
    Hi Tom,
    Yes, once of the modules inside the Macro Container is a .NET Macro
    Basically what I'm trying to achieve is this:
    I have a <umbraco:Item field="sidebarModules" recursive="true" runat="server" /> in the Master Template, however on the "DateFolder" pages,
    I need to show the sidebarModules from another node.
    sidebarModules is a Macro Container.
    I don't know if there is an alternative solution to acheiveing this?
    Peter.
    Dec 21, 2011 @ 15:24
    Tom Fulton
    Hmmm, that might be tricky.
    One thing you could experiment with is the nodeId attribute on the <umbraco:Item tag, ex:
    <umbraco:Item field="sidebarModules" recursive="true" runat="server" NodeId="1234" />
    This *should* cause the macro to render but using data from the node 1234.  However I'm not sure if you can pass that in dynamically or not, maybe you can with some inline C#  NodeId='<%=something%>' ...
    -Tom
    Dec 21, 2011 @ 15:45
    Peter Drayton
    Tom,
    You're a star. Simply adding NodeID="xxx" worked :-)
