Server Error in '/' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] umbraco.presentation.umbracobase.restExtension..ctor(String extensionAlias, String methodName) +1337 umbraco.presentation.umbracobase.requestModule.httpApp_PostAcquireRequestState(Object sender, EventArgs e) +712 System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +148 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75 Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.237
/base & members using default restExtensions.config problem
Trying to use umbraco.presentation.umbracoBase.library.member that is already present in restExtensions.config in a Umbraco 4.7.1.Beta installation
Trying to invoke method using URL below
http://localhost:50799/base/currentMember/login/mtv/password.aspx
Keeping getting below error message
Any ideas?
