How did you solve this issue? What steps did you go through to clear the client dependancy cache? I have suddenly xperienced the exact same issue in a 4.7.1.1 version after having worked in it for over two weeks, and I cannot seem to get it fixed. I get the error on all nodes that are of a document type with the RTE.
Thank you very much for your advice. Unfortunately it did not solve my issue :(
I have tried the trick you mentioned. I have tried to remove and paste in the umbraco-folders,. I have tried to remove the ~/App_Data/TEMP/ClientDependancy folder. I have tried to change <compilation debug="true" /> to <compilation debug="false" /> and back again. But so far without luck. Right now I'm looking into a complete reinstall of umbraco as it seems there is something completely wrong with umbraco after my upgrade to 4.7.1.1 - unfortunately :(
I have the exact same problem, I've tried the steps described in this thread without success, I suppose reinstalling Umbraco is the most viable option at the moment?
In addition to clearing out the ClientDependency folder and bumping the version number, I believe you also need to touch the web.config for the changes to take effect (add a blank line, delete, and re-save). Not sure if you already tried that but thought I'd mention it.
I have made a complete re-install as I couldn't resolve the issue above. Something I thought of afterwards was that I did have some external projects in VS2010 that compiled into my solution. These had umbraco references (DLL's) that I hadn't updated to the DLL's from 4.7.1.1. I don't know if this would solve the issue, but I definately think you have to remember updating the DLL's in your referenced projects. Just a thought :)
I've just experienced the exact same issue, and I was indeed referencing old binaries in VS2010, as soon as I copied the newer binaries across it started to work again.
Method not found: 'umbraco.macro umbraco.macro.GetMacro(System.String)'.
Experiencing an odd issue with a upgraded Umbraco 4.7.1 to 4.7.1.1 install.
In the back office when I click on a node with the RTE this error with thrown, can anyone help me fix this?
This is the stack trace
Matt Brailsford suggested clearing the client dependancy cache. this fixed the issues.
Cheers Matt :)
Hi Matt,
Thanks a lot in advance :)
Cheers Kim
Hi Kim
I opened ~/config/ClientDependency.config and changed the tag <clientDependency version="1"> to <clientDependency version="2">
Jon
Hi Jon
Any other help would be much appreciated :)
Regards Kim
Unfortunatley I cant be of much more help, I've not had too much trouble with CD so I'm no expert.
-Tom
Hi Stefan,
What are your thoughts?
Regards Kim
Hi Kim,
Mike
Hi Michael,
Thanks for verifying that it solved your problem. So updating referenced binaries seem to be the solution to the issue! :)
Kim
