  • Rasmus Lynggaard 118 posts 325 karma points
    Apr 17, 2012 @ 16:27
    Rasmus Lynggaard
    Examine fields.add working same way as lucene?
    I'm trying to add tags to a node through Examine.
    I'm using the GatheringNodeDataEvent and looping through the tags on the node. Instead of just a comma seperated list, I would like to add each tag as its own value on a field.
    In Lucene I would do like this:
    foreach (var tagId in tagIds)
    var tag = new Node(Convert.ToInt32(tagId));
    d.Add(new Field("Tag", tag.Name, Field.Store.YES, Field.Index.ANALYZED, Field.TermVector.YES));
    Where d i s my Lucene document. This works and adds several fields called Tag with different values on the document.
    I've tried to do it like this:
    foreach (var tagNode in tagNodes)
    e.Field.Fields.Add("tag", tagNode.GetProperty("title").Value);
    This gives me the follwing error:
    "An item with the same key has already been added."
    Do anybody have an idea on how to accomplish this through Examine?
