I'm running Umbraco 4.7.2 and i'm having a problem with the MembershipProvider and the RoleProvider. The member data needs to be stored in a different DB than the Umbraco. This means I have to use a custom MembershipProvider (for authentication etc,) and a custom RoleProvider (to retrieve some extra information about the member from my DB).
The MemberType node disappears in the Members section as soon as I configure a custom MembershipProvider in the web.config. I found a hint that the MembershipProvider has to have the name "UmbracoMembershipProvider". In this case the MemberType node really reappears but my custom MembershipProvider is not being used at all. Insteadthe Umbraco implementation is being used although the type in the web.config says differently.
Using RoleProvider with custom MembershipProvider
Please help. Thanks
