I'm trying to load a Node which is in level 5 in my tree (I have confirmed this in umbraco.config).
Loading nodes up to 5 works fine with this code, but not for level 5 itself. It's strange. What's going on here:
public List<Core.Objects.SystemGoal> GetSystemGoals(int activityId) { var goals = new List<Core.Objects.SystemGoal>(); var node = new Node(activityId); foreach (Node child in node.Children) { if (child.NodeTypeAlias == Constants.UmbracoDocTypeAliases.SystemGoal) { var goal = new Core.Objects.SystemGoal(); goal.Id = child.Id; goal.Name = child.GetProperty(Constants.UmbracoDocTypeProperties.Heading).Value; goal.Description = child.GetProperty(Constants.UmbracoDocTypeProperties.SubHeading).Value; goals.Add(goal); } } return goals; }
Node.Children is always empty even though I know there are children.
Thanks,Greg.
Won't let me edit, but I'm using 4.8.1.
Just like to clarify as I've actually described the problem wrong!
It's not that the node isn't loading, this actually does work fine:
The problem is when I try to get children of that node, for some reason it's always empty even though it has children and they are all published:
Level 5 node doesn't load with nodeFactory
public List<Core.Objects.SystemGoal> GetSystemGoals(int activityId) { var goals = new List<Core.Objects.SystemGoal>(); var node = new Node(activityId); foreach (Node child in node.Children) { if (child.NodeTypeAlias == Constants.UmbracoDocTypeAliases.SystemGoal) { var goal = new Core.Objects.SystemGoal(); goal.Id = child.Id; goal.Name = child.GetProperty(Constants.UmbracoDocTypeProperties.Heading).Value; goal.Description = child.GetProperty(Constants.UmbracoDocTypeProperties.SubHeading).Value; goals.Add(goal); } } return goals; }Node.Children is always empty even though I know there are children.
Greg.
