  • Andreas Johansson 9 posts 42 karma points
    Nov 09, 2012 @ 14:37
    Andreas Johansson
    How to iterate a "Related Links" using C#
    Hi!
    I'm having trouble using the umbraco default datatype "related links". My problem is that I want to iterate the property's children/options. I've seen examples using xml and xslt but I'm wondering if there's any possibilty to use pure c# inside a User Control.
    Something like this (But a working variant)
    Node node = new Node(Node.getCurrentNodeId());
    var linklist = node.GetProperty("link");
    if (node.GetProperty("link") != null)
    foreach (var item in linklist)
    //get each item here
    Thanks!
    Nov 11, 2012 @ 12:10
    Jeroen Breuer
    Do you have some code on how to do this in Razor? You can also use that code in a UserControl. Have a look here: http://our.umbraco.org/forum/developers/razor/27417-Use-Razor-code-in-UserControl?p=1#comment102639
    Jeroen
    Nov 12, 2012 @ 09:49
