  • Matt Bliss 176 posts 234 karma points c-trib
    Nov 29, 2012 @ 23:11
    Matt Bliss
    Examine dll Problem
    I've created a user control for an Umbraco 4.9.1 site based on the Umbraco TV Examin example at http://umbraco.com/help-and-support/video-tutorials/developing-with-umbraco/examine.aspx
    The project compiles without any problems but when I add the user control to an Umbraco Macro and try to view the page the following error is shown on the page:
    Error creating control (usercontrols/SearchResultList.ascx).
    Maybe file doesn't exists or the usercontrol has a cache directive, which is not allowed! See the tracestack for more information!
    and then this in the stack trace:
    Error creating usercontrol (usercontrols/SearchResultList.ascx)
    c:\...\usercontrols\SearchResultList.ascx(9): error CS0234: The type or namespace name 'SeachResults' does not exist in the namespace 'Examine' (are you missing an assembly reference?)
      at System.Web.Compilation.AssemblyBuilder.Compile()
      at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
      at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
      at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
      at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean ensureIsUpToDate)
      at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
      at umbraco.macro.loadUserControl(String fileName, MacroModel model, Hashtable pageElements)
    What am I missing?
    Nov 30, 2012 @ 13:22
    Ismail Mayat
    Can you paste codebehid of .ascx pls
    Nov 30, 2012 @ 13:38
    Matt Bliss
    Sure, here it is
    using System;
    using System.Linq;
    using System.Web;
    using System.Web.UI;
    using System.Web.UI.WebControls;
    using Examine;
    namespace MyNameSpace
        public partial class SearchResultList : System.Web.UI.UserControl
            protected string SearchTerm { get; private set; }
            protected IEnumerable<SearchResult> SearchResults { get; private set; }
            private string[] propertyAliases;
            public SearchResultList()
                SearchTerm = string.Empty;
                SearchResults = new List<SearchResult>();
                propertyAliases = new string[]
                    "pageTitle",
                    "pageDisplayTitle",
                    "pageSummary",
                    "mainContent",
                    "column1",
                    "column2",
                    "column3",
                    "column4",
                    "listTitle",
                    "listEntries"
            protected void Page_Load(object sender, EventArgs e)
                SearchTerm = Request.QueryString["s"];
                if (string.IsNullOrEmpty(SearchTerm)) return;
                var criteria = ExamineManager.Instance
                    .SearchProviderCollection["FrontEndSearcher"]
                    .CreateSearchCriteria();
                var filter = criteria
                    .GroupedOr(propertyAliases, SearchTerm)
                    .Not()
                    .Field("umbracoNavHide", "1")
                    .Compile();
                SearchResults = ExamineManager.Instance.SearchProviderCollection["FrontEndSearcher"].Search(filter);
                SearchResultRepeater.DataSource = SearchResults;
                SearchResultRepeater.DataBind();
    Dec 03, 2012 @ 12:42
    Matt Bliss
    Sorry silly mistake a typo in the .ascx file!
