I have a document type called "FAQ Item", however I have an issue in that the "Remove At" date keeps getting set to the current date and time. If I go into an item and clear the date, then click "Save and Publish", then navigate back to the item, the date has been set to the current date and time again. This happens on existing FAQ items and newly created FAQ items.
Has anyone every experienced a problem like this before?
Nodes unpublishing problem
No need to cross post :)
Sorry, I wasn't sure which topic it should go under :)
No problem :)
Most problems get picked up pretty quick, I'm not sure the topics headings are always relevant on here so not your fault.
