First i have a simple ASP.NET Question: When you have the ASP.NET form it will only submit to the current page. But have can i submit the form to another page?
And then i have a translation problem. When im sending pages to translation, umbraco give this error:
Column 'Name' does not belong to table .
Description: An
unhandled exception occurred during the execution of the current web
request. Please review the stack trace for more information about the
error and where it originated in the code.
Exception Details: System.ArgumentException: Column 'Name' does not belong to table .
Source Error:
An unhandled exception was generated during the execution of the
current web request. Information regarding the origin and location of
the exception can be identified using the exception stack trace below.
1) You can only have one 'runat' form on a page and it can only post to the same page. However,y ou can write out a standard html form via an xslt macro, this form can post/get to any location. You will need to output this outside of your "runat" form.
To read the submitted form fields in the resulting page/controls you will need to use
C#
HttpContext.Current.Request["formFieldId"];
xslt
umbraco.library:Request("formField")
2) Can't help here. Never used the translation features.
Regarding second issue (the translation issue) -> known issue, and reported on Codeplex! Go and vote for it! I would like to have this resolved in a next version as I'm using this feature on daily basis.
Simple ASP.NET Question and translation problem
Hello
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.ArgumentException: Column 'Name' does not belong to table .
Source Error:
Version Information: Microsoft .NET Framework Version:2.0.50727.4016; ASP.NET Version:2.0.50727.4016
Greetigns Anders
C#
xslt
Hi Anders,
/Dirk
Hello again..
I found it myself.. <asp:Button ID="Button1" runat="server" PostBackUrl="~/Default2.aspx" Text="TargetButton" />
Thank you for the other things..
