  • Barry Fogarty 493 posts 1129 karma points
    Apr 10, 2013 @ 19:07
    Barry Fogarty
    MVC: Using the UmbracoHelper dictionary in a Partial View with a custom model
    I have a contact form child action called as follows:
    @Html.Action("RenderContactForm", "ContactFormSurface")
    The action in the controller returns a partial view with a custom model passed in to it as follows:
    return PartialView("ContactForm", new ContactFormModel());
    Do I need to pass something in to this view so I can access the UmbracoHelper methods?  I cannot inherit UmbracoTemplatePage from this view as it uses a custom model.
  • Charles Afford 1163 posts 1709 karma points
    Apr 10, 2013 @ 22:31
    Charles Afford
    Hi i had the same problem.  I created a new property in my model NodeId.
    I instanced my model in the view assigned the property value and then passed the model in to the partial.
    In the partial i could then instance a new Node passing in my NodeId.  Hope this helps.  Charlie :)
    Apr 10, 2013 @ 22:33
    Charles Afford
    102
    You can also do:  I think its
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<YourCustomModel>
    its explained half way down on this page :)
    http://umbraco.com/follow-us/blog-archive/2012/10/30/getting-started-with-mvc-in-umbraco-410.aspx
    Apr 12, 2013 @ 10:52
    Barry Fogarty
    #H5YR Charlie.  I should have clarified, I wanted to use a dictionary value with Umbraco.GetDictionaryValue("") so the second method was what I needed.
