  • Marius 21 posts 91 karma points
    Apr 25, 2013 @ 17:15
    Marius
    Setting up membership problem
    I was trying to set member profiles with instructions from http://www.aaron-powell.com/umbraco-members-profiles.
    I stuck at adding properties to web.config: I can't find <profile> element. Tried to insert <properties> in <membeship>, but my application will not start. What is a proper way to access profile properties in Umbraco v6.0.3 ?
    Regards
    Marius
  • Charles Afford 1163 posts 1709 karma points
    Apr 25, 2013 @ 21:25
    Charles Afford
    Hi, use my post @ Charles.afford.com will explain how to do this :D.  No need to use the webconfig if you dont want to.  Let me know how you get on.
    Charlie
