Best way for Creating CMS using features of existing CMS in umbraco
Im newbie in Umbraco 4.11..and i think that this is not a new requirement. All most experienced Umbraco developers would have solved this out earlier..
I've created one simple CMS using Umbraco, now i want to create exactly same CMS but for other project.
i copied the whole project with different name but that doesn't work, because both projects point to the same database!!!
Well, yes, depending which DB you're using, you need to duplicate that database (for sql server, backup, create new, restore) and set connection string to new database in web.config file.
Is there any good way doing what i want to do?
