I've succesfuly implemented Facebook login on Umbraco in my local development environment running Umbraco 6.0.5.
On the production server however, i only get errors when trying to login with Facebook.
I have located the problem to the method Member.AddMemberToCache. If i comment out those two rows i don't get any errors (but the member isn't logged in either).
MESSAGE: Exception has been thrown by the target of an invocation. STACKTRACE: at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Umbraco.Web.BaseRest.RestExtensionMethodInfo.Invoke(String[] parameters) INNEREXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object.
at MyProject.FacebookLogin.createNewUser(Object facebookUser)
at MyProject.FacebookLogin.LogUserIn()
Here is a piece of my code that is throwing errors.
private static String createNewUser(dynamic facebookUser)
MemberType siteUser = new MemberType(1088); // Facebook user type
Member newMember = Member.MakeNew(facebookUser.name, facebookUser.id.ToString(), facebookUser.email.ToString(), siteUser, new umbraco.BusinessLogic.User(0));
Member.AddMemberToCache(newMember);
return newMember.Id.ToString();
Umbraco version is 6.1.1. I didn't have this problem in 6.0.5.
Problem with Member.AddMemberToCache
private static String createNewUser(dynamic facebookUser) { MemberType siteUser = new MemberType(1088); // Facebook user type Member newMember = Member.MakeNew(facebookUser.name, facebookUser.id.ToString(), facebookUser.email.ToString(), siteUser, new umbraco.BusinessLogic.User(0)); Member.AddMemberToCache(newMember); return newMember.Id.ToString(); }Umbraco version is 6.1.1. I didn't have this problem in 6.0.5.
