Using Umbraco 4.11.7 all been working fine. Just created a new page which is a child of the home page. In the razor macro I have and also when i output page id in the template the page is always seen to be the home page. The page has id of 1761 however when i do Model.Id its the home page id. Anyone seen this before? I have tried to delete the page and recreate it does the same thing.
In the umbraco tables and xml cache the page is correct 1761 I cannot see why it thinks its the home page?
First thing I would check. Is there a template with the same name as child page? Could be a routing issue, that causes the home page to be rendered with a different template, instead of rendering the child page?
You are the man the main #h5yr. I had page called SearchResults and template with same name hence it was doing home page with that template. However I guess the routing should obey allowed templates which it clearly does not?
Tha altTemplate does not obey the list of allowed templates. But I think it would make sense if it preferred to show the page, and not the template, when the page actually exists.
Model issue
Guys,
Regards
Ismail
Morten,
Anyhow I renamed and it all works.
Many thanks
Ismail
Glad it worked :)
I guess its routing order is template first then page? Anyhow you live and learn.
Cheers
Ismail
