IPublishedContent to Strongly Typed Model / Custom View Model?
Note that I'm using custom everything (custom MVC routes, custom controllers, custom view models etc. I'm not interested in using the default routing & controller per doctype).
As I understand it, the ContentService should only be used for node manipulation and that for 'reading' I should be using UmbracoContext.ContentCache and the methods on there (e.g. GetSingleByXPath()) that return IPublishedContent. Is this correct?
I have several strongly typed models set up BlogPost and StaffProfile, given that these inherit from RenderModel what is the best way to convert them to strongly typed models? or custom view models?
For example a route that is /blog/authors/john-bear/ would list all blog posts by that author, using a custom view model;
public class BlogPostAuthorViewModel
// properties
public StaffProfile StaffProfile { get; set; }
public IEnumerable<BlogPost> BlogPosts { get; set; }
// constructor
public BlogPostAuthor() {
BlogPosts = new List<BlogPost>();
And in the controller...
public ActionResult Author(string authorName)
// create model to return
var blogPostAuthorViewModel = new blogPostAuthorViewModel();
// #TODO - fetch author and all blog posts
// finally pass back to view;
return View("~/Views/Blog/BlogPostAuthor.cshtml", blogPostAuthorViewModel );
As I see it, there are myriad of ways to achieve the middle bit #TODO - fetch author and all blog posts. I could use Examine or XPath.
For setting the author I could do;
// get the id of the author
var authorXpathQuery = String.Format("//StaffProfile[@nodeName='{0}']", authorName.Replace("-"," "));
var publishedAuthor = umbracoContext.ContentCache.GetSingleByXPath(authorXpathQuery);
if ( publishedAuthor != null )
// turn into render model
var staffProfile = new RenderModel(publishedAuthor, CultureInfo.CurrentUICulture);
// and into my custom strongly typed StaffProfile object
var author = new StaffProfile(staffProfile.Content, staffProfile.CurrentCulture);
// and add into the render model
blogPostAuthorViewModel.Author = author;
Is this approach correct? Is there an easier way to do this?
ContentServiceshould only be used for node manipulation and that for 'reading' I should be usingUmbracoContext.ContentCacheand the methods on there (e.g.GetSingleByXPath()) that returnIPublishedContent. Is this correct?I have several strongly typed models set up
BlogPostandStaffProfile, given that these inherit fromRenderModelwhat is the best way to convert them to strongly typed models? or custom view models?For example a route that is
/blog/authors/john-bear/would list all blog posts by that author, using a custom view model;And in the controller...
#TODO - fetch author and all blog posts. I could use Examine or XPath.For setting the author I could do;
